Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-17-2011, 08:34 AM   #1
Walls
How do I repair spider cracks in the corner of my walls
marjac001 is offline   Reply With Quote
Old 11-17-2011, 09:31 AM   #2
Super Moderator
Walls
Pictures ---or a better description----It's O.K. to use more than one sentence----we don't mind.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
MikeKy55 (11-18-2011), Willie T (11-19-2011)
Old 11-18-2011, 07:22 PM   #3
Drywall contractor
Walls
Agree....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Old 11-19-2011, 03:35 AM   #4
paper hanger and painter
chrisn's Avatar
Walls
Kill the spiders?
The Following User Says Thank You to chrisn For This Useful Post:
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
