Wallpaper Removal Gone Awry. Advice To Get Back On Track? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 08:27 AM   #1
Question
Wallpaper removal gone awry. Advice to get back on track?
Hi! A few weeks ago I started this thread and got some fantastic advice: Stripping wallpaper - what is this in the photo and how to fix?
I decided to do one section of the downstairs of the home at a time starting with the hallway. I tore down the paper, washed the walls, sealed with GARDZ, patched with joint compound, resealed with GARDZ, primed, and painted two coats. The hallway looks great - smooth, no bubbling or other issues.
I started to work on the large wall in the family room tonight and it's a disaster. They wallpapered OVER wallpaper and in some parts the first layer of wallpaper was put directly onto the plaster or directly onto some sort of putty they used for patching. The plaster is crumbling away in chunks. Will the steps I followed to do the hallway work? I would seal the wall and work on patching everything up with joint compound, but I am wondering:
Do the walls need to be re-plastered or patched with plaster instead? If yes, what specific product do I look for? I read that a product called EasySand could be used for this. Would that do the trick?
Here is an image of the current mess: http://imgur.com/1Eem6rP
Here is a closeup of the plaster crumbling down to the concrete: http://imgur.com/mko9NsI
Thank you for the advice.
handsforasl is offline   Reply With Quote
Old 02-03-2013, 08:49 AM   #2
Rewards Points: 6,034
Yes easy sand will work for your first skim coat. If you have not worked with it before here is some tips;
get the longest trying one you can find at least 90 minute
mix in small batches
put on as smooth as you can
when it starts to get stiff in your pan throw it out CLEAN out your pan and all tools and make another batch. The reason for this is if you add more water thinking you can use it longer it will weaken it. It dries by a chemical process and once it starts it can't be stopped. You MUST clean all tools because if the process has started with the mud on your tools that will start the process in your new batch.
mix with hot water speeds the process, cold water will slow it down.
Hope this makes sense to you. Good Luck
Old 02-03-2013, 08:53 AM   #3
Yes, that all makes sense, thank you for the tips! Looking at the links to the product last night I figured I would want the longer drying one so I had time to spare.
Should I put GARDZ on the wall first?
You said the EasySand can be used as the "first skim coat". What other coats or steps would I need to follow to get the job done? I was under the assumption I could use the EasySand to fill in the holes in the plaster.
Old 02-03-2013, 10:16 AM   #4
To put the Gardz on the wall first will not hurt anything and will seal the wall. Use the easy sand to fill holes but then use regular mud to put on a thin skim coat and feather out away from the repair that will help to hide the repair. Usually the first coat is pretty rough so sand down any ridges between coats. Also what size knife are you planning to use?
Old 02-03-2013, 10:19 AM   #5
Thanks. I had cross-posted this into the painting forum that helped me out before: Wallpaper removal gone awry. Advice to get back on track?
It was suggested I use the compound I already have instead of the EasySand and to use a larger knife to help get a thin layer.
Old 02-03-2013, 10:35 AM   #6
The advice you got over there from Mike is spot on
Old 02-03-2013, 10:39 AM   #7
Yay! Glad another pro agrees! Off I go to get the rest of the stuff I need. :-)
Thank you very much.
The Following User Says Thank You to handsforasl For This Useful Post:
ToolSeeker (02-03-2013)
Old 02-10-2013, 03:41 PM   #8
UPDATE: Wallpaper removal gone awry
I'd say thanks to the friendly and helpful guys here I am back on track!
Just finished the 4th (and final) skim coat today. :-)
ToolSeeker (02-10-2013)
Old 02-10-2013, 03:50 PM   #9
DIY staff
Rewards Points: 7,174
That's some nice work----you have a natural talent----
I'll bet you frost a nice cake,too-----
Old 02-10-2013, 07:58 PM   #10
And if the wallpaper will not come off get a good steamer and hold it on for a few minuets longer it will come off with a good heavy scrapper
Fjohn2304 is offline   Reply With Quote
Old 02-10-2013, 10:10 PM   #11
Thanks!
I am hoping the rest of the walls aren't as bad but I'm not counting on it...lol Now that I have a system down it will hopefully go faster.
Speaking of frosting a cake, I am using my old handheld mixer to whip/mix the mud.
oh'mike (02-11-2013)
Tags
plaster crumbling , wallpaper removal
Wallpaper removal & brown paper backing _alphaBeta_ Drywall & Plaster 4 09-10-2012 08:26 PM
Guidance on surface prep after wallpaper removal jd3030 Drywall & Plaster 1 06-05-2012 04:40 PM
removed old back splash, now need advice ddono Kitchen & Bath Remodeling 2 03-29-2011 12:07 PM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 10:14 AM
Another "Need some advice on wall removal or support" thread onemo Building & Construction 11 04-14-2009 06:47 AM
