Wall Problem. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 11:20 AM   #1
Wall problem.
Well I am currently living with my parents in a rented home. My room is in the basement right next to my brothers room and the wall is just 1 peice of 1/2 drywall and I keep getting woken up in the middle of the night from him screaming.
I was looking online on how the build a new wall but my problem is the "wall" already exists I just need to make it thicker with soundproof insulation. how should I go about doing this?
chrispl57 is offline   Reply With Quote
Old 10-06-2012, 11:28 AM   #2
the Musigician
DangerMouse's Avatar
Is there drywall on BOTH sides of the wall, or just the one? There are a few ways to approach this problem, and other members will chime in with helpful advice. You should check with the landlord, of course, before proceeding, as he/she may offer you a reduction in rent to upgrade the wall, especially if you plan on finishing it. (texture, paint, paneling, etc.)
DM
Old 10-06-2012, 11:36 AM   #3
DM
Not really sure what you mean. There's no frame to the wall and its just a sheet of drywall (dont understand how they did that.) Also I would give it a try but the ammount of repairs that have had to be done in the past 2 years I don't see her wanting to lol (new toilet, door, furnace, water heater ect)
Old 10-06-2012, 11:57 AM   #4
the Musigician
I don't understand. The drywall is just attached on the edges? ....or not at all?
How is it held in place?
DM
Old 10-06-2012, 11:59 AM   #5
Ill take some pictures hold on
Old 10-06-2012, 12:01 PM   #6
the Musigician
That would have been my next suggestion. Photos nearly ALWAYS help us to help you here.
DM
Old 10-06-2012, 01:04 PM   #8
Rewards Points: 5,974
I will try this, Mouse, add on if you think I'm right. Do you see in the pic of the I think, it was a light switch, there looks like framing. If it is you can add a fiberglass insulation, like they use in attics, it comes in a roll. Fill the cavities between the framing members, then a sheet of (I would probably use 5/8") drywall screwed to the framing. You could probably use sheeted styrofoam between the framing too. Neither of these methods will eliminate the sound but will muffle it somewhat. You can get a drywall called quiet rock but it runs about $100 a sheet. Maybe someone else has a better idea.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Wiring problem in the wall, what to do? hohadcr Electrical 8 07-27-2009 08:22 AM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
