Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-02-2010, 06:07 PM   #1
Professional Wood Shafter
ryanh's Avatar
wall plaster repair
Posting for a friend. As i havent had to do any plaster repairs before. Only work with drywall..
He had some kind of issue around the windows with cracks, so he chipped away the top coat to explose the brown coat. Can see all the horse hair lol. So just buy some plaster repair mix and float it out?
Drywall won't bond to the brown coat its like cement. right?
ryanh is offline   Reply With Quote
Old 03-03-2010, 08:32 AM   #2
Drywall contractor
wall plaster repair
I have used regular Durabond (brown bag, not easy-sand) over brown coat. It works as long as the brown coat is not "crumbly". You might prime first with oil primer to seal it also. Build up with Durabond and skim with ready-mix. I've never resorted to plaster mix, but that should work. If the brown coat is not in good shape I generally cut it out too, add layers of drywall to get proper thickness, then finish....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-04-2010, 12:09 AM   #3
ryanh's Avatar
wall plaster repair
So just fill in the spot to bring the thickness out to the same as the finished surface and then feather it out wide with a top coat of ready mix? Whats a good readymix that is somewhat sandable ?
Old 03-04-2010, 04:12 AM   #4
paper hanger and painter
chrisn's Avatar
wall plaster repair
For the final coat SHEETROCK® Brand Easy Sand™ Lightweight Setting-Type Joint Compounds
Old 03-04-2010, 07:53 AM   #5
Drywall contractor
wall plaster repair
USG "green lid" will work fine for a final skim to save mixing. Easy Sand will work also....
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to fix old plaster on brick wall - any hints? Leah Frances Building & Construction 1 01-14-2010 06:55 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Plaster wall - cutting out an access hole, but how to replace it? Steelmesh Building & Construction 8 11-07-2008 10:40 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
