Wall Peeling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 07:50 AM   #1
Wall peeling
Some of my wall bubbled and peeled after I applied primer, what can I do to prep the wall for primer again?
Wdstedman is offline   Reply With Quote
Old 06-17-2012, 02:47 PM   #2
Rewards Points: 258
I had a simiilar experience once with BEHR paint. What brand did you use? Here are a few leads as to what may have caused the problem:
1. old paint especially paint that froze in the winter
2. low grade paint
3. the drywall compound had not fully set
4. wrong type of primer
5. very humid weather
This is not meant to be a definitive list. Just a few random thoughts. Once you determine the issue you will know what to do. Let the paint dry, sand and apply joint compound and smooth imperfections. Then start over correcting what may have been the original problem.
retired guy 60 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 05:02 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
