Wall Niche - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 01:15 PM   #1
Wall niche
I saw a lowe's commercial a few time's here lately and there is a women who does a wall niche with a glass backsplash, and i believe it had trim work at the bottom(kinda like a window seal). I thought of doing one in my bathroom and was wondering the best way to do this. Here's the pic at what i'm working with...
1) (cut the stud in wall and reinforce?) Center and frame it with 2x4's?
2) Drywall and Corner bead's?
3) Tape the inside corners or paintable caulk?
I have searched alot and only come back with expensive pre-made stuff.
Thanks!!
Tyler
tomknox is offline   Reply With Quote
Old 09-07-2011, 01:20 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you don't want to pay for a pre-made niche, build one yourself.
So what's the question if there is a question?
XXX
Old 09-07-2011, 04:10 PM   #3
Anybody else got any suggestions on how you personally like to build them? Thanks!
Old 09-07-2011, 04:14 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
After all I have done for you, you just throw me under the bus like that???
I am crushed!
XXX
Old 09-07-2011, 04:33 PM   #5
Bud stop!! I almost feel outta my seat laughing. You're a dang trip! I ass-u-me i'm on the right track then hey??
Old 09-07-2011, 04:46 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh yow...sorry. I thought you had a plan already.
I would build the frame separate from the wall first, it is easier to square things up that way. Then once you have the box built to size scribe it to the 2X's that interfere and cut out that section of 2X. Slide the box in its place and screw back to the severed 2X. You could brace it some more if need be but it won't be necessary because the drywall will hold everything in place. Glue the drywall to the frame. Then also glue the drywall inside the frame. Don't bang on it or try to screw it. Mud the junctures and it is ready for paint after sanding a little.
This IS NOT in a shower is that correct?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
tomknox (09-07-2011)
Old 09-07-2011, 10:13 PM   #7
You liked my plan huh??? Bud yer gettin old if ya think a shower is goin in by my light switch Thanks for the advice! The drywall forum is slow...let's move it back to the floor department then...
Old 09-07-2011, 10:22 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well I'm not getting any younger - that's a fact. We see some really strange stuff around here from time to time and some people float in here with outrageously goofy ideas sometimes and they want our blessings and for us to sprinkle Holy Water over their conjuring. I had to ask.
XXX
Old 09-07-2011, 10:27 PM   #9
Just pokin w/ya, you're a gentleman and a scholar!
Old 09-07-2011, 10:31 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"MOM"! "He called me a scholar"!!!
XXX
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
