-   -   Wall anchors - how to remove (http://www.diychatroom.com/f101/wall-anchors-how-remove-165443/)
maxman10 12-03-2012 05:33 AM
1 Attachment(s)
Any suggestions for how to remove these metal drywall anchors?
Attachment 61356
MissKat 12-03-2012 05:39 AM
I usually drill the face out and let the anchor drop behind the wall. I am no expert though and am curious to see if anyone thinks this is a bad idea.
tribe_fan 12-03-2012 05:48 AM
Google "Molly bolt" to see what you are dealing with. I have done all three in order of ease.
1) If they are recessed a little just patch over.
2) Drill the heads off with a drill slightly larger than the hole. and leave the rest in.
3) Put the screw in a few threads , then tap to straighten. Wiggle and pull it out.
dvmbound1977 12-03-2012 05:57 AM
Push em in
I usually push them into the wall as well. A simple pop with a screw driver and hammer or you could screw in and pull out too. All will work, will still need to patch no matter what.
ToolSeeker 12-03-2012 06:28 AM
I have had nothing but bad luck with this type of anchor if you try to pull them out it usually takes a chunk of drywall with it. I have not tried drilling them out, but I will.
bjbatlanta 12-05-2012 02:46 PM
I knock them through, tape and a couple of coats of mud over the holes, sand, and you're good to go...
ToolSeeker 12-05-2012 04:11 PM
To just knock them thru looks like it will leave a pretty good size hole.
bjbatlanta 12-05-2012 04:34 PM
Only as big as the outside of the anchor. Use a punch or phillips screwdriver...
jeffnc 12-05-2012 06:26 PM
You can slice the heads off with an angle grinder and a metal cutoff wheel.
jbfan 12-05-2012 07:03 PM
I use the ball of a ball peen hammer and recess them, them mud over them.
gregzoll 12-05-2012 07:19 PM
Knock them through, or use a pair of needle nose pliers to pull out and make a bigger hole.
