Is It Viable To Avoid Mesh Tape Altogether? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 09:20 PM   #1
Rewards Points: 1,062
Question
is it viable to avoid mesh tape altogether?
i have heard from multiple people they only use paper tape and never mesh even for center-wall joints. i would like to hear some more opinions on whether it is prudent to simplify with just paper tape or should mesh indeed be used in the middle of the wall.
i understand this is more of a matter of preference than a rule but just checking
Old 05-01-2012, 09:40 PM   #2
Member at Large
No need to use mesh tape if you don't want to.
Paper tape makes a stronger joint anyway because it cannot move on the bias.
I do drywall finishing and repairs and have never used mesh tape.
oldpaintdoc is offline   Reply With Quote
The Following User Says Thank You to oldpaintdoc For This Useful Post:
user1007 (05-02-2012)
Old 05-01-2012, 09:49 PM   #3
Rewards Points: 512
its a personal. everyone is different. i just started a job a week ago, my previous employer only wanted me to use mesh and now my new employer swears by paper tape. done correctly they both work fine.
princelake is offline   Reply With Quote
The Following 2 Users Say Thank You to princelake For This Useful Post:
mae-ling (05-03-2012), user1007 (05-02-2012)
Old 05-02-2012, 07:53 AM   #4
Too Short? Cut it Again!
I used mesh tape only for what is meant. Fixing cracks.
For drywall seams I always used paper tape for the reasons mentioned.
Old 05-02-2012, 07:55 AM   #5
Originally Posted by princelake;912288 [COLOR=Red
done correctly they both work fine[/COLOR].
Indeed
Old 05-03-2012, 09:22 PM   #6
Drywall contractor
Rewards Points: 1,070
I too only use mesh for small repairs. New work is paper only.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
amakarevic (05-03-2012)
Old 05-04-2012, 12:40 AM   #7
Registered User
Rewards Points: 4,924
If you will have any kind of structural movement at all later, causing a crack, use paper tape- it doesn't stretch: http://www.usg.com/rc/technical-arti...ems-en-PM5.pdf
Tips: http://www.usg.com/rc/data-submittal...ata-MH1178.pdf
Gary
Old 05-05-2012, 12:10 AM   #8
firehawkmph's Avatar
Rewards Points: 1,800
To each his own. I have used mesh for many years now on additions, basement remodels, garages, etc. I haven't had any problems with cracking. I use the ultra thin mesh now. It is easier to work with than the older, thicker mesh. We can debate over which is stronger. I say there are so many variables on how different people tape that it's a moot point. So use whatever you want, whichever you feel most comfortable with.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 05-07-2012, 03:32 AM   #9
I use paper tape most of the time, only using mesh for cracks and small repairs-when i'd use 20 minute setting compound for the repair.
Both will work fine, just remember that the mesh is meant to be imbedded with a "setting compound" as in the powdered stuff, not all purpose you buy in the bucket ready to go. My understanding is that you risk cracks imbedding mesh tape with all purpose.
chrisBC is offline   Reply With Quote
Old 05-07-2012, 09:59 PM   #10
That's exactly right Chris. I use the easy sand products for the first two coats, then dust control premix for the final coat.
Mike Hawkins
The Following User Says Thank You to firehawkmph For This Useful Post:
chrisBC (05-07-2012)
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 04:45 PM
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 10:09 PM
Drywall Tape baum Drywall & Plaster 3 10-09-2009 12:04 PM
mesh tape with redgaurd ponch37300 Remodeling 3 04-07-2009 10:31 AM
Mesh drywall tape...2 questions scarrell Building & Construction 4 03-27-2006 11:51 PM
