Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 12-09-2010, 12:12 PM   #1
Very, Very noticable ceiling height issue
This is small area above a closet entry way on the 2nd floor. The wall was installed parallel to the old kneewall and plumb. Apparently there is some serious sag to the 70 year old roof.
Anyway, my drywall guy told me that it wouldn't be a big deal and he'd just fill it in with some mud. Obviously, that didn't work out so good.
I'm hoping somebody can help me come up with a way to hide this issue without ripping down the new drywall. Was thinking maybe a trim board ripped at an angle or a cove molding?
Any ideas?
Very, Very noticable ceiling height issue-2010-12-08_18-34-00_819.jpg   Very, Very noticable ceiling height issue-2010-12-08_18-33-08_955.jpg   Very, Very noticable ceiling height issue-2010-12-08_18-33-52_171.jpg
Nick DIY is offline   Reply With Quote
Old 12-09-2010, 03:52 PM   #2
Next Time...New Build
Did your drywall guy put the additional mud on the wrong side???
Without knowing what the rest of the room is like, you could do a beam type thing. I did this where I had painted paneling meet the unpainted paneling ceiling. You use 1 x 3 boards and attach them in an L pattern. The vertical piece is ripped to the angle of the ceiling and you attach it.
Again, this may not work depending on what the rest of the room is like.
A 2 inch difference is a lot to make up over a few feet.
Good luck.
RickyBobby is offline   Reply With Quote
Old 12-10-2010, 08:43 PM   #3
No perfect fix that I've ever found.
Is the doorway at the top of a stairwell? Looks like it might be. Anyway, sometimes it's ok to just let it be the way it is.
Adding molding (2" over a couple feet) is gonna be hard to hide that amount of difference no matter how you cut it.
Shamus
Shamus is offline   Reply With Quote
Old 12-11-2010, 01:25 AM   #4
Wire Chewer
Red Squirrel's Avatar
I would look at possibly turning that into a round archway, or at least make the top part parallel with the ceiling, instead of level with the floor. Though that might look weird too...
Old 12-11-2010, 11:38 AM   #5
Well, thanks for the input. I know I'm pretty well out of luck here. Cant do anything with the doorway as this opening will house a set of bi-fold doors.
I'll probably just have to shim it out, re-drywall and re-mud it.
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
paint color vers: ceiling height rrekih Interior Decorating 1 07-24-2010 01:50 PM
Ceiling Fan wiring issue BeauBrown Electrical 0 06-05-2010 10:37 AM
Suspended Ceiling Min Height? mfleming Building & Construction 6 10-17-2008 09:42 AM
Basement ceiling height? jrepp Building & Construction 5 10-06-2008 09:57 AM
