Very Large Wall Bulge - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 04:36 PM   #1
very large wall bulge
I suddenly discovered a very large bulge in a wall separating my bedroom from the upper portion of a two-story living room. As far as I know, it's a framed wall with drywall. It's about 8-10 feet long, extends out about 1.5 inches; and is about 1.5-2 feet tall. It's kinda freaking me out.
Anyone know what could cause this and/or know what kind of repair is needed?
chriscronin is offline   Reply With Quote
Old 02-15-2012, 04:50 PM   #2
DIY staff
Rewards Points: 7,174
We need a picture---is there a corresponding hollow on the living room side?
How old is the house?
I have some ideas but will wait until I hear your answer.
Old 02-15-2012, 05:49 PM   #3
Rewards Points: 13,968
Is this something new that just showed up or did you just notice it?
Is there any cracks in the drywall or plaster?
Old 02-15-2012, 09:25 PM   #4
answers to q's
The house in 13 years old. I just noticed the bulge, but it's been there long enough to gather dust.
The bulge is actually bulging out on the living room side. There's no corresponding hollow on the bedroom side.
There are no cracks associated with the bulge.
Old 02-15-2012, 09:34 PM   #5
Maybe cut it open and take a peek?
mschrade is offline   Reply With Quote
Old 02-16-2012, 12:01 AM   #6
DIY staff
Could be---
Loose drywall---improperly attached long ago--(common)
2x4 went crazy after construction---warping out the wall (fairly common)
Improper framing --stacked wall 'hingeing' at the joint--(very unlikely)
Gymschu (02-16-2012)
Old 02-16-2012, 08:07 AM   #7
Only one way to find out what's going on. Remove the drywall.
Old 02-16-2012, 11:28 AM   #8
Gymschu's Avatar
Rewards Points: 930
Could be a dead body in there!
Old 02-16-2012, 11:39 AM   #9
Ironlight's Avatar
If it's bulging on one side and is concave on the other then dollars to donuts it's warped framing. If it gathered dust and there are no cracks of any sort then I would not worry about it...it was probably warped when the house was taped blocked and sanded.
If I had any worries it would be that water was getting in somewhere. Is there a step in the roof level where the bedroom wall meets the living room wall? If so I would just check the flashing/drainage along there. It's an unlikely issue however if you don't have any other signs of water damage, but just enough moisture might be getting in there to warp the wall.
Ironlight is offline   Reply With Quote
Old 02-16-2012, 01:15 PM   #10
Smile
thanks
Thanks to all for their helpful questions and advice. If I find a body in there, I will be sure to let you know (unless of course my wife tells me to bury in the backyard in the dead of night).
Thanks, too, to oh'mike for his helpful suggestion regarding location - Delaware in the good ole USA.
I'll be sure to check for the possibility of water getting in there.
Frankly, I'm relieved to hear that it could be the somewhat simpler issues that you have all suggested, presence of corpse nothwithstanding.
Old 02-16-2012, 04:21 PM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
[quote=chriscronin;855093]Thanks to all for their helpful questions and advice. If I find a body in there, I will be sure to let you know (unless of course my wife tells me to bury in the backyard in the dead of night).
Frankly, I'm relieved to hear that it could be the somewhat simpler issues that you have all suggested, presence of corpse nothwithstanding.[/quote]
THAT could be an issue
Old 02-16-2012, 08:58 PM   #12
Gymschu's Avatar
Rewards Points: 930
Don't laugh too much about the dead body thing. A local contractor began to dismantle some drywall in a kitchen addition. The stench was almost unbearable. They found the remains of a mentally disabled teen who had been wedged into the wall space BY HIS LOVING PARENTS, the previous owners of the home. It happens!
Old 02-17-2012, 03:14 AM   #13
chrisn's Avatar
Rewards Points: 474
yuk
Old 02-17-2012, 05:50 AM   #14
Learning Things Every Day
Jay 78's Avatar
That's taking 'tough love' a bit too far....
Under Construction
Jay 78 is offline   Reply With Quote
Old 02-17-2012, 11:37 AM   #15
retired union carpenter
Send a message via Yahoo to coupe
I believe it's one of Oh Mike's suggestions, or someone attached a 2x nailer wrong? rockers usually are paid by the sheet, wont take time to fix framing members. though it seems to me like a ledge, if collects dust? a bulge dust would slide down.
only way to know for sure is tear it out and see!
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 12:30 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
