Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-15-2012, 02:05 PM   #1
Vertical vs Horizontal revisit
Since I can't do math, I'd like to edit this to a theoretical question instead.
If you are hanging drywall on a narrow wall, is there any reason not to just hang a wide panel vertically to avoid having to tape and mud joints?
Thanks!
Last edited by RebeccaHCMT; 07-15-2012 at 02:37 PM. Reason: Apparently I can't do math.
RebeccaHCMT is offline   Reply With Quote
Old 07-15-2012, 03:24 PM   #2
If it's less then 4' then there's no reason not to hang it vertical.
mae-ling (07-18-2012)
Old 07-16-2012, 07:44 PM   #3
if the studs are perfectly on 16oc then i always hang them vertically, i find its alot easier on your shoulders when taping/mudding. the only downfall is its a little tougher for a newbie to eyeball where the stud is when screwing the board up but thats why they invented tape measures.
princelake is offline   Reply With Quote
Old 07-18-2012, 01:43 AM   #4
Less than 4' always go vertical when possible.
Over 4' then go horizontal, seams show less this way.
Also use longest sheets possible.
mae-ling is offline   Reply With Quote
Old 07-19-2012, 10:16 AM   #5
Thanks so much!
I appreciate the info and quick responses!
Hang drywall vertical or horizontal nickm1024cobra Drywall & Plaster 54 03-30-2011 12:37 PM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
Hanging drywall - Vertical or Horizontal? RobbL Building & Construction 20 09-14-2010 07:48 PM
Vertical or horizontal installation Tom241953 Drywall & Plaster 7 07-20-2010 08:53 PM
horizontal or vertical plywood sheathing. Clutchcargo Building & Construction 6 07-12-2009 02:51 PM
