Vertical Or Horizontal Installation - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 11:16 AM   #1
Vertical or horizontal installation
I'm drywalling my garage walls and wanted to know what is the best method to hang it, vertical or horizontal.. One wall has 2 windows. the height of the walls is under 8 foot..
Thanks in advance..
Tom
Tom241953 is offline   Reply With Quote
Old 07-19-2010, 08:52 PM   #2
Phoenix
i much prefer horizontal.
Axecutioner-B is offline   Reply With Quote
Old 07-19-2010, 10:25 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
I vote horizontal as well.
Hanging vertical is better on metal framing. Wood is just not as true as metal.
-Paul
Sir MixAlot is offline   Reply With Quote
Old 07-20-2010, 11:43 AM   #4
Handyman
Rewards Points: 512
My general rule is, anything 4 ft or less I go vertical...anything wider I go horizontal
canadaclub is offline   Reply With Quote
Old 07-20-2010, 11:54 AM   #5
Chicago, IL
Michael Thomas's Avatar
As long as you are working with an 8 foot ceiling or less and/or you are trying to maximize material usage and you need less material on way or the other, IMO it's a matter of personal preference.
Once you go over 8 feet, vertical installation means you will be taping un-tapered edges (unless you use 10 or 12 foot sheets, or just need a narrow strip that will be hidden behind the base molding).
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 07-20-2010, 01:23 PM   #6
Old School
Willie T's Avatar
Go horizontal and use butt strips for joining the un-tapered ends...... never any more butt-to-butt mud hump problems.
I can't, for the life of me, understand why anyone butts horizontal drywall on studs or joists anymore. Unless, of course, you have a group of dinosaurs down at your building department, and they still insist on it being done that way.
Horizontal also makes for cleaner ceiling joints since the ceiling lid is smoothly supported for the full length of the upper sheet.
And it goes without saying - or it should - keep all fasteners back away from corner and/or ceiling joints by at least 8" to 12". You will greatly help eliminate future cracks there. This is especially important for ceilings when you are using trusses.
Willie T
Old 07-20-2010, 08:47 PM   #7
Chicago, IL
For those not familiar with this technique:
http://www.finehomebuilding.com/how-...tt-joints.aspx
Old 07-20-2010, 08:53 PM   #8
Registered User
Rewards Points: 5,266
Willie, you'll like my tip of the week....... I just started it earlier today- lol.
Be safe, Gary
Tags
horizontal , installation , vertical
Hanging drywall - Vertical or Horizontal? RobbL Building & Construction 20 09-14-2010 07:48 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 01:40 PM
Sheet Rock vertical or horizontal chefcrazymike Building & Construction 10 10-21-2009 02:20 PM
horizontal or vertical plywood sheathing. Clutchcargo Building & Construction 6 07-12-2009 02:51 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
