Vapor Barrier In Garage Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 09:58 PM   #1
Vapor barrier in garage ceiling?
Attached garage not finished except ceiling and walls adjacent to house. I would like to insulate and drywall the walls. The ceiling is not insulated and does not have vapor barrier installed. Do I need vapor barrier in ceiling? I will not be heating in winter, live in Wisconsin so summers can be hot and winters can cold.
Any suggestions?
titaniumring is offline   Reply With Quote
Old 10-23-2010, 08:46 AM   #2
Drywall contractor
Rewards Points: 1,070
I have never seen a vapor barrier on a ceiling other than face paper on the insulation, but different areas have different ways of doing things. I wouldn't think it necessary......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-23-2010, 11:06 AM   #3
can I install the insulation with paper facing down stapling it to sides of the rafters? or should I just insulation without facing? or use blown in insulation.
Old 10-23-2010, 04:03 PM   #4
If you plan to insulate, you should use a 6 mil poly vapour barrier on the walls and ceiling. Paper faced insulation is not a good vapour barrier.
Polywanna is offline   Reply With Quote
Old 10-23-2010, 05:00 PM   #5
If you aren't heating it don't bother with plastic
Just use paper faced insulation
Old 10-23-2010, 05:42 PM   #6
Registered User
Rewards Points: 526
Why are you insulating the garage?
Will you have a portable/permanent heat out there?
Gary
Old 10-24-2010, 11:22 AM   #7
I am insulating the garage to regulate the temperature a little better. In the summer it gets warm from the sun and in the winter it can get chilly. I will not be heating it on a regular basis, i may use a portable heater to keep it warm enough to work while I am in the garage.
The problem I am having is what to do about the ceiling. The ceiling is finished with drywall but no plastic.
Old 10-24-2010, 01:27 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I'd do it, just because it's cheap and not that hard to do so while you're there may as well. At least then, it's done. I've also been told you should use acoustic sealant but wow that stuff is a pain to work with and good luck getting it off anything if it drips, which it will! I usually don't bother. The drywall pressing on the plastic should provide a decent seal imo.
Old 10-24-2010, 08:12 PM   #9
I want to put the vapor barrier in... but, the ceiling is already drywalled so whatdo I do now??
Old 10-24-2010, 08:16 PM   #10
Registered User
Rewards Points: 526
Vapor barrier primer paint, this will stop the moisture off the cars before it permeates the drywall. I would not use one in your location on the walls.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
titaniumring (10-24-2010)
Old 10-24-2010, 08:46 PM   #11
Wire Chewer
Rewards Points: 132
Ohh I figured it was just studs at this point. I'd do as suggested by GBR then. trying to add VB from the attic would be like pulling teeth.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 10-18-2011, 12:15 PM   #12
Vapour barrier in the ceiling
Gary
Hey guys,
I have been following this thread don't want to distract from the line of questining but didn't want to start a whole new thread. I actually have a bedroom above the garage and the floor is freezing. I pulled down the plaster ceiling in the garage and there is old wax paper backed (paper facing down) insulation. I want to insulate this area as well and will not be heating the area. Do I need to install vapour barrier against the underside of the floor boards and then insulate with fiberglass before drywalling it in? What is the layering system? I am in the Pacific Northwest so there is a lot of moisture in the air.
Dino
DinoB is offline   Reply With Quote
Old 10-18-2011, 01:19 PM   #13
I'm in the same boat as 'titaniumring'. I have a twinhome with an attached garage that is not heated, and to help keep the cold air from coming in through the garage into the basement I would like to insulate the ceiling. It is completely sheet rocked and the walls are insulated. I'm going to blow in insulation but had the same question about a vapor barrier. And I was also wondering if I need to put in soffit baffles? I would also like to heat it, but I don't want my electric bill to double. Any suggestions? Great to learn about the vapor barrier primer paint!
elway07 is offline   Reply With Quote
Old 10-20-2011, 03:27 PM   #14
Rewards Points: 252
Gary
Do cars give off that much moisture that you need a vapor barrier? I'd pass on doing the vapor barrier on the ceiling.
jburchill is offline   Reply With Quote
Old 10-20-2011, 08:14 PM   #15
Wire Chewer
Rewards Points: 132
From my understanding the garage should be treated as outside, so yeah I'd put one. Especially if its not heated 24/7.
Hip roof garage ianmacneil Building & Construction 7 07-02-2014 11:18 AM
cracked ceiling joist near garage door support mikebull Building & Construction 1 07-06-2010 05:20 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Adding an Electrical Outlet in garage Ceiling myworkshop Electrical 3 03-09-2009 12:40 AM
Garage ceiling has 2X4 joists-will it hold? markd Building & Construction 13 01-06-2009 02:46 PM
