Using Moisture-resistant Sheetrock In Dry Locations - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 03:12 PM   #1
Rewards Points: 1,062
Question
using moisture-resistant sheetrock in dry locations
i was wondering if there are any issues with using green sheetrock in dry locations and combining it with regular. just because i have some leftovers green. i think it would be fine cause the green is just a superset of the regular, correct?
Old 05-11-2012, 03:48 PM   #2
Ravenworks's Avatar
You'll be fine
Ravenworks is offline   Reply With Quote
The Following User Says Thank You to Ravenworks For This Useful Post:
amakarevic (05-11-2012)
Old 05-13-2012, 11:31 PM   #3
Registered User
Rewards Points: 5,492
Unless it's a ceiling application; 1/2" board = 12"o.c. framing: http://publicecodes.citation.com/ico...002_par013.htm
Gary
Old 05-13-2012, 11:39 PM   #4
huh ?
Old 05-14-2012, 02:10 AM   #5
He's referring to that it's not recommended to hang from ceilings (maybe OK with 12'' centers instead of 16''). It's not as strong as regular rock in that regard. Although i'm sure a small patch wouldn't be a big deal.
chrisBC is offline   Reply With Quote
The Following 2 Users Say Thank You to chrisBC For This Useful Post:
amakarevic (05-14-2012), Gary in WA (05-14-2012)
Moisture high in slab weddingness Flooring 5 11-13-2009 07:27 PM
Help with moisture behind sheetrock in garage Spirit General DIY Discussions 4 10-10-2009 08:21 PM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 11:51 AM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 10:15 PM
Repairing Weather Resistant Barrier DawnGen Building & Construction 9 10-26-2008 05:18 PM
