Using Durabond As The Base Coat For Veneer Plastering - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 11:31 PM   #1
using durabond as the base coat for veneer plastering
i put up blue board and used durabond for my joints. since the joints needed to be feathered and the ceiling to wall feathered, i just continued to apply durabond as the base coat. then i used two coats of veneer finish plaster as my top coat. ...my question is...was that the wrong way to do it?...but the final result is that it looks great. any answers or advantages/ disadvantages of doing it this way?
zach081129 is offline   Reply With Quote
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
troweling plaster on brick mattroos General DIY Discussions 3 02-11-2007 12:11 PM
