Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-09-2009, 09:46 AM   #1
Using drywall for Drop Ceiling
Trying to decide on drywall or drop ceiling. Then I thought, how about a combination?
Has anyone ever installed the drop ceiling framework (Main Support, T-bars etc) and instead of using tiles, used 4'x4' pieces of drywall?
Will the drywall buckle over time?
Maybe 2' x 4' pieces of drywall would work better.
Just wanted to get some thoughts on this.
Thanks,
Rick
rickkeeter is offline   Reply With Quote
Old 02-09-2009, 10:04 AM   #2
Old School
Willie T's Avatar
Yes, it will likely sag, is hard to get in and out of a grid system without damaging it, and it is heavy as hell.
Willie T
Old 02-09-2009, 11:48 AM   #3
Moderator
Termite's Avatar
Light gauge steel framing can certainly be used for a dropped ceiling, but not a T-bar grid. There's too much weight for the grid to handle, and there would probably be some sagging anyhow.
Old 02-10-2009, 08:39 AM   #4
gravity always wins
There are grid systems designed for drywall panels. In fact the big companies offer gypsum cored lay in ceiling panels. See the Armstrong or USG ceiling sites for their grid recommendations. You will certainly need more tie wires than a normal fiber panel tile lay out. There are certain fire code applications that gyp core panels will meet.
Old 02-10-2009, 10:24 PM   #5
4 X 4 panels is too large and will sag. 2 X 4 panels are common and can be bought in HD or Lowes. It's a heavy system often used commercially. Just be sure to use plenty of wire supports.
retiree is offline   Reply With Quote
Old 02-11-2009, 12:36 AM   #6
nap
You talking to me?
nap's Avatar
I prefer the look and the longer period of no sag with 2x2.
as to drywall panels, in commercial kitchens with drop ceilings, it is require to use a vinyl coated tile. Most of them I have used are vinyl covered sheetrock. Works fine.
lots of the proper size of support wires.
Old 02-12-2009, 12:05 PM   #7
Drywall contractor
If you have a humid basement, the 2'x4' "tiles" will sag over time. Go with a 2'x2' grid in that case. Plain drywall will work for tiles. Paint to your liking. The vinyl tiles are pretty expensive.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-13-2009, 07:07 AM   #8
I never heard of this before. take some pictures when youre done.
But I would agree with everyone about the larger ones sagging in time ( no pun intended ) and I would go with the 2X2's and to protect the edges you could attach 1/2" J bead to all four sides.
II Weeks is offline   Reply With Quote
Old 02-13-2009, 08:52 AM   #9
Drywall contractor
The J mold would be overkill. The vinyl coated sheetrock tiles from the USG have raw edges. I've installed miles of them with no problem.......
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
