Upside-down Drywall On Ceiling? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 01:43 PM   #16
Drywall contractor
Rewards Points: 1,070
Got it! I guess I wasn't quite "seeing it" clearly. The only one who can justify "overkill" is you.......but it does sound like more trouble than it's worth.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-01-2008, 12:28 AM   #17
Rewards Points: 6,652
$15 is too much. Sorry, but poor excuse.
Old 11-01-2008, 03:34 AM   #18
the Musigician
DangerMouse's Avatar
$15 IS too much!!! what do you mean, poor excuse?
i'm sorry we're poor... GOOD excuse!
DM
Old 11-01-2008, 09:57 AM   #19
Oh, but you have money to cover the ceiling in expensive wood product to hide your mistake. Where are the priorties.
Old 11-01-2008, 10:31 AM   #20
the Musigician
perhaps i should elucidate... =o)
panels - bought at auction for $10.00 for 200 approximately 15"x61" in size. most in excellent condition, some crappy pieces.
walnut strips - created from my woods costing me time and labor is all.
1 gallon polyurethane - $20.00
screws - maybe $10.00
so a 300 sq. ft. one-of-a-kind ceiling for about $40.00 seems to me to be a GOOD thing. agreed?
and it wasn't about covering up a mistake, it was just so i wouldn't have to move that piece to the next joist over and do two half sheets on either side of it. that would have worked too but was more work. i planned from the start to do the ceiling this way, so as long as there's no fire safety issue or code problem, i'm ok with it.
DM
Old 11-01-2008, 10:43 AM   #21
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
like the rock guys said, it's no problem so I wouldn't worry about it regardless of the cost. If it was free yet there was no problem with hanging it backwards, I still wouldn;t fix it.
being frugal isn't being cheap. It's merely being wise with your assets.
Old 11-01-2008, 10:51 AM   #22
the Musigician
yup! today i'll be working on the center of the room access hole/fan-light area. i decided to drywall the inside of the box i created.
now to do a drywall sheet with wood and support framing from some 4" walnut to make a cover. const. adhesive will hold it together, and screws will mount it via frame to ceiling, then i start the strips! woohoo!
DM
Old 11-01-2008, 01:51 PM   #23
Originally Posted by bjbatlanta View Post
Hang it backwards and glaze coat the whole piece to slick it out. The back paper it much "coarser" than the face paper. Otherwise, no harm, no foul. I've done it a time or two myself, usually just pulling the measurement from the wrong side of the board in a hurry. If I have enough rock, I'll re-cut. If it's a toss between finishing up or going to get one more sheet, I'll hang it backwards....
I agree it happens every now and then no big deal I don't know how true it is but I been told to hang upside down when going over it with plaster,strucktolite regards Rob
super carpenter Rob is offline   Reply With Quote
Old 11-01-2008, 01:54 PM   #24
the Musigician
good point... i wondered about that too, wouldn't plaster stick better to a rougher surface?
DM
Old 11-01-2008, 01:59 PM   #25
Drywall contractor
Not sure if that's the case or to eliminate the tapered edge..........or both.
Old 11-01-2008, 03:19 PM   #26
nap
You talking to me?
nap's Avatar
DM
You use a different board when plastering. Blueboard.The paper is designed to absorb the water and not cause a problem and it is designed to allow the plaster to hold.
Old 11-01-2008, 04:15 PM   #27
Drywall contractor
Nap is absolutely correct, there is a specific type of board for plaster. I was speaking more in terms of a repair where you don't have access to blueboard. Naturally, it would be best to use the proper "backer" board. Thanks for the clarification......
Old 11-06-2008, 02:14 PM   #28
the Musigician
ok, i said i'd keep you guys posted, here is pic of the ceiling started--> My $40 (300 sq. ft.) Homemade Birch/Walnut Ceiling
DM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Drywall over existing ceiling? billybarty Carpentry 1 03-07-2008 11:05 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 08:27 AM
