Uneven Livingroom Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 05:59 PM   #1
uneven livingroom walls
When you measure your wall going from east to west and the measurements go up and down. What is the best way to measure you drywall so do not have to use so much mud.
Jillyon is offline   Reply With Quote
Old 04-05-2011, 06:21 PM   #2
Old School
Willie T's Avatar
Uh.... Huh?
Willie T
Old 04-06-2011, 09:13 AM   #3
Drywall contractor
Rewards Points: 1,070
Yeah, I don't quite follow either....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-06-2011, 09:16 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Avoiding seams is what I think you're asking.
Install your drywall horizontally.
If you have a 9' wall, get 10' sheets = 1 seam
If you have an 11' wall, get 12' sheets = 1 seam
hope that helps
tcleve4911 is offline   Reply With Quote
Old 04-06-2011, 11:31 AM   #5
Rewards Points: 120
Or are you perhaps referring to the corners not being plumb, such that the wall is, for example, 11'6" long at the bottom, but 11'6-3/4" long at the ceiling? As tcleave suggested, run your drywall horizontally, cut it to the shortest length, and the gap should be relatively insignificant in 4'. If that is still going to leave too much gap, just use a level to see how much runot you have in 4', and slice your drywall accordingly.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
uneven walls, what about door jam johnnyboy Building & Construction 4 10-24-2010 04:18 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
