#1 |
uneven framing for drywall
Hi, This is a beginner's question. Thanks for reading.
I put together a partition wall framing. Now I found that there are some unevenness among the studs and I probably need to so some "shimming?" before I put drywall on. The unevenness is around 1/8-1/4 inch. Is there any kind of long and thin thing to be put on the framing for filling the gaps? Thanks again. |
#2 |
I had the same problem when I did my first framing job.
What I did, and I don't know if this is what you are suppose to do or if this is what the pros do, but I just nailed another stud beside it, to straighten it out. Worked for me. Hope this helps. |
#3 |
Moderator
http://www.lowes.com/lowes/lkn?actio...0652-157-00100
Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#4 |
Thanks.
GBR in WA, I know there need to be some kind of shims. Do you screw the shims on before drywalling? This particular shims I have never seen in the HDs in my area. I will ask further. I am up in Canada. Other than the ready-to-use drywall shims, there is nothing simply to fix the problem? |
#5 |
Moderator
Find the bowed out stud, cut 3/4 the way through it from the side it needs to move to, attach a plywood gusset (3"x16") to both sides, nail it off when in line. Drive a wood shim in the gap with glue between the cut ends.
Be safe, Gary
#6 | |
Old School
uneven framing for drywallQuote:
![]() And the alternative way is to make the same cut from the other side, the convex side.... you'll use no wedge..... then force the stud away from you by toe-nailing the edge of the stud downward and upward (angled) across the cut. (This is if you cannot reach the concave side conveniently.)
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 10-31-2009 at 07:04 PM. |
#7 |
I've never heard of cutting and shimming. Would be cool to try that, I guess. Could imagine it might be a pain.
I reno'd my bathroom and the studs were very uneven. I heard you can use furring strips but could not find them anywhere ( until after ) so I just cut out the crap studs and replaced them. I've heard alot of people will just splice the junk studs on a 45* and knock them back and sister a new stud. Whatever works! |
| Display Modes | |
| Shoring Up Exterior Wall Framing Questions | Tom5151 | Building & Construction | 6 | 09-30-2009 05:55 PM |
| Framing for drywall under Spiral staircase | clemon03 | Drywall & Plaster | 6 | 07-17-2009 04:49 PM |
| framing material estimate | maydoug | Building & Construction | 38 | 06-12-2009 02:32 PM |
| Framing Gun - Nail Shank Diameter Questions... | MoparAutoworks | Building & Construction | 5 | 07-03-2006 10:27 PM |
| Framing a 16 foot high wall for shop | pranderson | Building & Construction | 10 | 01-01-2006 05:23 PM |
