-   -   uneven framing for drywall (http://www.diychatroom.com/f101/uneven-framing-drywall-56063/)
hohadcr 10-27-2009 09:48 AM
Hi, This is a beginner's question. Thanks for reading.
I put together a partition wall framing. Now I found that there are some unevenness among the studs and I probably need to so some "shimming?" before I put drywall on.
The unevenness is around 1/8-1/4 inch. Is there any kind of long and thin thing to be put on the framing for filling the gaps?
Thanks again.
yummy mummy 10-27-2009 11:01 AM
I had the same problem when I did my first framing job.
What I did, and I don't know if this is what you are suppose to do or if this is what the pros do, but I just nailed another stud beside it, to straighten it out.
Worked for me.
Hope this helps.
Gary in WA 10-27-2009 11:07 AM
http://www.lowes.com/lowes/lkn?actio...0652-157-00100
Be safe, Gary
hohadcr 10-27-2009 02:11 PM
Thanks.
GBR in WA,
I know there need to be some kind of shims. Do you screw the shims on before drywalling?
This particular shims I have never seen in the HDs in my area. I will ask further. I am up in Canada.
Other than the ready-to-use drywall shims, there is nothing simply to fix the problem?
Gary in WA 10-27-2009 03:11 PM
Find the bowed out stud, cut 3/4 the way through it from the side it needs to move to, attach a plywood gusset (3"x16") to both sides, nail it off when in line. Drive a wood shim in the gap with glue between the cut ends.
Be safe, Gary
Willie T 10-27-2009 03:39 PM
3 Attachment(s)
Be safe, Gary
Here is the sequence up to the point of nailing on the side plywood gussets. I didn't show that because I think we all know how to nail a piece of plywood on the side of a stud. :yes:
And the alternative way is to make the same cut from the other side, the convex side.... you'll use no wedge..... then force the stud away from you by toe-nailing the edge of the stud downward and upward (angled) across the cut. (This is if you cannot reach the concave side conveniently.)
295yards 10-29-2009 05:42 AM
I've never heard of cutting and shimming. Would be cool to try that, I guess. Could imagine it might be a pain.
I reno'd my bathroom and the studs were very uneven. I heard you can use furring strips but could not find them anywhere ( until after ) so I just cut out the crap studs and replaced them.
I've heard alot of people will just splice the junk studs on a 45* and knock them back and sister a new stud.
Whatever works!
