Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-17-2013, 01:38 PM   #1
Uneven Ceiling
The wall is 16 ft so two 8 ft boards fit perfectly. The problem I have is there is a section of the ceiling that bows slightly due to the way the wall was constucted (not changing this). If I get the right side flush, the left side is out. If I get the left side flush, the right side is out.
Option 1 - Get the right side against the wall and ceiling flush leaving just the left out. This will put the board at a slight angle making a butt joint tough to match.
Option 2 - Left side flush leaving the right ceiling and wall out 1/4 inch or less and hope the mud hides everything.
Option 3 - Furrow out some of the board where the cieling dips to allow a better fit on either side of the dip.
I am leaning toward option 2 but would love to get some opinions on different options. Thanks!!
JerseyMike is offline   Reply With Quote
Old 01-17-2013, 02:13 PM   #2
Uneven Ceiling
Set the board level, or scribe it in for a tighter fit.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling issue wooten General Discussion 5 06-06-2011 08:20 PM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-19-2011 12:44 AM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 11:30 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
