Ultralight Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 10:13 PM   #1
Thumbs up
Ultralight drywall
Has anybody had any experience with this yet? 30% lighter than regular.
Honza is offline   Reply With Quote
Old 01-22-2011, 05:09 PM   #2
Drywall contractor
Rewards Points: 1,070
Yes. Wish it had been around 35 years ago when I started in this business. I might have avoided a couple of back, neck, and shoulder surgeries.... According to the mfgr., it's stronger than regular 1/2" in spite of being lighter. Supposedly good for spanning 24" centers instead of 5/8" even with water base texture applied. You can check it out at USG.com
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 01-24-2011, 01:05 PM   #3
I think ultra light and magnesium oxide will dominate the market in the next few years. My only concern with light weight drywall is that mass is the best thing to absorb sound. You may be sacrificing sound deadening qualities which can be compensated for in other ways
masterofall is offline   Reply With Quote
Old 01-25-2011, 11:36 AM   #4
Full disclosure: I am affiliated with USG and wanted to provide some additional information to this discussion.
Thank you for your interest in SHEETROCK UltraLight Panels. These panels have been thoroughly tested and perform equal to or better than standard wallboard panels. Regarding sound, SHEETROCK UltraLight Panels perform in the same relative range as standard panels. There are many factors that affect sound performance, including mass, flanking paths (anyplace air can go, sound can go), reverberation, absorption, and dead air space. Most typical residential wood framed walls and ceilings perform relatively poor on sound control. Also, since most typical residential rooms have windows and doors, the sound rating for the walls is not very effective. Unless, or course, high performance windows and doors are used as well. Sealing of the perimeter of walls and penetrations such as outlet boxes with a sound sealant like SHEETROCK brand Acoustical Sealant is also very important for sound control. The wallboard is only one part of what can become a complex system when addressing all factors that can improve sound performance.
Feel free to check out http://www.theweighthasbeenlifted.com for more information and product availability.
ACS215 is offline   Reply With Quote
The Following 3 Users Say Thank You to ACS215 For This Useful Post:
Axecutioner-B (01-25-2011), brenda o (01-25-2011), firehawkmph (01-25-2011)
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
