Typical Room Dimensions + Corners? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 05:18 AM   #1
typical room dimensions + corners?
Hi!
When drywall is installed at the corners of the room, does one of the two pieces of drywall get installed in the half-inch corner, or is there a space in the corners? Am I supposed to leave a 1/8" gap at the corners?
That is...
Is the drywall installed like this (underline represents 1/8" gap):
OOOOOO
X
X
X
X
Or like this (note the gap in the corner plus extra 1/8" gap represented by underline):
_OOOOO
X
X
X
X
Thanks!
cwm9 is offline   Reply With Quote
Old 03-10-2010, 07:28 AM   #2
Remodeling Contractor
no gaps. One to the corner and the other tight to the first drywall sheet.
Old 03-11-2010, 07:49 AM   #3
Drywall contractor
Rewards Points: 1,070
Get it as tight as you can. Due to walls/ceilings being out of level/plumb, you may end up with a slight gap anyway. Or it may be tight at the top, a slight gap at the bottom of the board. Tape will cover it.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-18-2010, 11:54 PM   #4
Hang your board tight into the corners. If you have a gap that is about 1/4" or more then consider filling the gap with a setting type compound and letting it set up before mudding in your corner with paper tape.
Unlike wood paneling, drywall does not need a gap for expansion. Drywall joints are like a frog's butt, tighter is better.
Ron Franck is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
advice/Help on non-permitted bonus room? Orange_County General DIY Discussions 43 06-11-2010 05:06 PM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
First Question: How to cool this room? Warhammer: 3025 HVAC 4 03-25-2009 10:02 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
