Type Of Drywall For Basement - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 01:48 PM   #1
Type of drywall for basement
Can someone please help advise me on which type of drywall to use in my basement. Is the mold resistant mold worth the extra money? Basement is currently dry but I'm sure some moisture is hiding somewhere.
Also, would you recommend insulating? It's plenty warm now in its unfinished state so I was wondering if there were other reasons we should insulate for?
Thanks.
Jilltsb is offline   Reply With Quote
Old 12-18-2011, 02:38 PM   #2
Military Mom of 4
Snav's Avatar
Location matters when you're discussing insulation.
I prefer to use greenboard. I use it for everything - it doesn't cost too much more. There are other types of wallboards to prevent mold-growth, though . . . up to you.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-18-2011, 11:08 PM   #3
Registered User
Rewards Points: 526
As Snav asked; where is the home? There may not be moisture showing as it dissipates when exposed to the basement air currents soon as formed. Did you tape a 2'sq. plastic to the slab and check next day for condensation? Or the wall?
The mold-resistant may work but water-resistant "greenboard" has the paper faces and edges treated to resist water passage; when in a basement- you want the moisture to pass through easily not resit passage.....
Gary
Old 12-19-2011, 07:04 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
For drywall below grade, I'd use either USG Mold Tough or GP Densarmor. Greenboard is sort of outdated. Not at all mold resistant.
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
