Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-20-2011, 02:52 AM   #1
Type of drywall
Wow, so many great responses to my other questions, thank to all.
So in my kitchen should I use the Aqua type of drywall & paper tape or fibre?
Tboy is offline   Reply With Quote
Old 11-20-2011, 07:57 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Type of drywall
regular drywall is standard practice in kitchens as its not subjected to neary as much moisture as a bathroom is., if you want a little more piece of mind though you could use a sheet or two around the sink area as this is where water will be
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Tboy (11-22-2011)
Old 11-21-2011, 12:48 AM   #3
Moderator
Type of drywall
Moved you to "Drywall" for better response....
http://www.usg.com/rc/data-submittal...ata-MH1178.pdf
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
Tboy (11-21-2011)
In wall gutter downspout causing mold on drywall. chrispy35 General Discussion 12 05-06-2011 11:35 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
