Two Questions About Drywall Job - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 07:17 PM   #1
two questions about drywall job
1st- When tearing down drywall to hang hardibacker I accidently pulled a chunk out by a window that measures 2 1/2 by 11in long. I cut a patch panel and screwed it in behind the corner bead around the window. So, now there is a gap between the new and old panel about 3/8 to 5/8 big. Is it ok to fill it with joint compound? I did the best I could with it but I am afraid its going to crack in the future.
2nd- The transistion between the hardibacker and the drywall is about 1/8 inch difference in height. the backerboard is 6 1/2 inches wide but I am only tiling 6 inches fron the side of the tub. This leaves me with about 1/2 in. difference from the backer to the drywall. What do I do there to hide the different depths of the two?
redblazerx is offline   Reply With Quote
Old 03-05-2010, 10:36 AM   #2
A pic sure would help.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 03-05-2010, 11:02 AM   #3
if i'm reading that right you can feather your mud out between the two and get a nice transition. 1/8" isnt that much.
cellophane is offline   Reply With Quote
Old 03-06-2010, 08:00 AM   #4
Drywall contractor
Rewards Points: 1,070
Agree on the pic..
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 04:17 AM
Drywall finishing - questions cody21 Drywall & Plaster 15 06-26-2009 04:53 PM
Drywall Questions LDO Drywall & Plaster 9 08-28-2008 04:47 PM
Have some drywall questions Mikedks Remodeling 20 01-09-2008 09:23 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
