Truss Uplift - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 02:25 PM   #1
Rewards Points: 1,092
truss uplift
i asked this in the building section, but have no answer so far. i have a garage that is 20' wide, and the trusses span that. i am in climate zone 8, so truss uplift due to temperature/moisture differential between the top and bottom chord will happen. i have no interior walls and will stop screwing the sheet rock to the trusses about 12" from the exterior wall. between the trusses there is blocking attached to the top plate of the wall to screw to. CONCERN: i have a truss that is parallel to a wall and only 8" away. i don't want to screw the 'rock to that truss, at least near the middle, and don't want to float the 'rock over to the next truss as that would give me a 32" float. i plan on installing blocking between the last and second last truss and screwing to that, staying 16" from the wall near the middle of the truss and 12" away from the wall near the ends of the truss. is that what is normally done? i don't see what else to do.
Old 04-24-2013, 12:10 AM   #2
I just dry walled all my ceilings in my house. It also has trusses where there is a truss closer then 16" from the wall i installed ladders between them and screwed into the ladders not the truss. Inspector approved it this way. Also i kept a 16" clearance from the walls all the way around.
k20vteck20 is offline   Reply With Quote
Old 04-24-2013, 12:18 AM   #3
k20: thanks. that is what i did, too. j
Sheet rock and truss uplift jklingel Building & Construction 13 01-04-2013 10:46 PM
Truss uplift repair for parallel wall wvphysics Drywall & Plaster 4 11-20-2010 02:54 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 01:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 08:36 PM
