Transition From Hardiebacker To Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 09:23 PM   #1
Transition from hardiebacker to sheetrock
I'm tiling the tub area where I just installed a new tub with a tiling flange. The tub instructions call for putting 1/4 inch furring strips down the studs that the backer board will be installed on. This will make for a smooth transition over the tiling flange. My question is how to make up for the 1/4 inch where the backer board will meet sheetrock (that doesn't have a 1/4 inch furring strip behind it)?
hurtman is offline   Reply With Quote
Old 02-04-2013, 09:55 PM   #2
Rewards Points: 256
I've never shimmed out my backer board like that. If i did, I'd put the same thing behind the sheetrock to make it even.
michaelcherr is offline   Reply With Quote
Old 02-05-2013, 01:19 AM   #3
Rewards Points: 13,458
You have to shim the whole stud not just where the backer board goes.
Old 02-05-2013, 06:16 AM   #4
I'm tiling up to the ceiling so I'll have backerboard all the way up the stud. My transition will be a vertical joint where the backerboard will meet the sheet rock that was installed years ago during construction.
Old 02-05-2013, 06:29 AM   #5
DIY staff
Rewards Points: 7,174
How thick is the tub flange---????
Usually , the 1/2" backer rests on the top of the flange and does not cover it---then that void is filled with thinset as the tile is installed.
If the walls are to be waterproofed before tiling---the void would be filled with thinset before the waterproofing is applied.
AS others have said----if you furr out any part of the wall, you must furr it all--
Tile requires a flat surface or the tile edged will 'lip' badly and you will hate it.
Old 02-05-2013, 08:23 AM   #6
Here's a link to the instructions for this tub:
http://www.us.kohler.com/webassets/k.../1084213_2.pdf
This shows the furring strips coming down to the tile flange and then the backerboard going over the flange. This is my first tub working with a tiling flange. Is this unique to tubs with tiling flanges?
Old 02-05-2013, 09:17 AM   #7
DIY staff
If you do as I suggested--stop the board above the flange and fill that gap with thinset--you will be fine---
Furring the wall is fine if you don't have to have the tub area board meet the drywall that is against the studs----those instructions sure weren't written by a person that actually installs these in the field.
His instructions are flawed---not addressing conditions found in real world construction.
Old 02-05-2013, 10:39 AM   #8
Thanks oh'mike. I'll do as you suggested.
The Following User Says Thank You to hurtman For This Useful Post:
oh'mike (02-05-2013)
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 11:37 AM
5/8" sheetrock and 1/2" hardiebacker problem pttcc Tiling, ceramics, marble 9 02-03-2011 02:51 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 01:32 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
