Transistion From Texture Plaster Ceiling To Newly Installed Smooth Drywall Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-11-2014, 11:52 AM   #1
Transistion From Texture Plaster Ceiling to Newly Installed smooth Drywall Walls
I am about to replace some paneling in a room with drywall that has a plaster textured ceiling, and it is in good shape.
Looking for methods to tape and mud the corners between the ceiling and walls without covering any of the texture on the ceiling.
A few years ago I tried to repair a small area of the plaster texture in another area of the house and it did not match it up very well.
I did not want to use molding around the ceiling and would prefer to not smooth coat the ceiling.
any details or web references would be appreciated.
jimybud is offline   Reply With Quote
Old 05-11-2014, 12:09 PM   #2
Jmayspaint's Avatar
Rewards Points: 536
Butt the wall boards up tight and caulk it.
Jmayspaint is online now   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Milwminded (05-12-2014), ToolSeeker (05-11-2014)
Old 05-12-2014, 11:26 PM   #3
Rewards Points: 18
Same question
I had the same question. Thank you!!
Milwminded is offline   Reply With Quote
Replacing drywall on walls but want to keep ceiling Arsinek Drywall & Plaster 15 02-09-2013 01:45 PM
i put drywall up and is bordered by plaster walls, the ceiling has the dimples and my joint is smooth. any tips on blending it? brettrawlings1 Drywall & Plaster 2 08-08-2011 09:14 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Stomp texture on old plaster ceiling? flatlander745 Painting 1 02-23-2010 02:03 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
