Topping Mud For First Coat??? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 05:34 PM   #1
topping mud for first coat???
I have four ~10in square patches to do in my garage. I have about a half a box of topping mud left. Is it okay to use topping as a first taping coat for small 10in square patches???
I realize all purpose is stronger, but the patches are at the tops of the walls and it is in my garage. I used the holes to fish wires from the attic.
mopowers is offline   Reply With Quote
Old 03-16-2010, 10:29 PM   #2
You can use it, but don't be suprised if it cracks. Spend the few bucks to use the optimal product.
beerdog is offline   Reply With Quote
Old 03-17-2010, 11:09 AM   #3
So topping mud has a tendency to crack if used as a first coat even on a small patch? I guess that means I'll be going down to pick up some all purpose. Just wish the drive wasn't so long.
Thanks.
Old 03-17-2010, 11:56 AM   #4
The best choice for a first coat on a patch is a setting type mud. Setting type is the strongest. Hell....you could use spakle but it may not last.
Old 03-17-2010, 01:32 PM   #5
Drywall contractor
Rewards Points: 1,070
Personally I don't use topping mud at all, but I sure wouldn't recommend it for first coat. All purpose ready mix or Easy Sand.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 07:17 PM
Is one coat of stain enough? hayzen Painting 8 09-03-2009 11:13 PM
Cracks in stucco scratch coat - is this normal? chadurban Building & Construction 5 05-25-2009 11:55 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
