Tips On How To Place Sheetrock In This Corner - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-21-2014, 07:10 PM   #1
Tips on how to place sheetrock in this corner
I removed a drop in tub as part of bathroom remodel and now need to install drywall (green board) to cover where the tub surround was so it will meet up smoothly with the existing drywall.
The photo shows the part of the wall that I'm seeking advice about where there is a 90+ inside angle that is finished with a curved angle.
Questions: 1.Any special tips on how I show install the two pieces of board that will form the inside angle?
2. How shall I proceed to do the taping and mudding of this angle so it matches the board above?
Thanks.
eddj is offline   Reply With Quote
Old 04-21-2014, 07:42 PM   #2
Rob
Robpo's Avatar
Rewards Points: 826
It is hard to tell from pic but if this is the shape this is how I would do it. Can't tell if there is anything to attach it to from pic but if there isn't you will have to put something.
Robpo is offline   Reply With Quote
Old 04-21-2014, 10:55 PM   #3
Thanks for reply.
There are studs to attach the board to.
Questions
  1. What do the blocks shown in your sketch represent?
  2. Should I just butt the two pieces of board together?
  3. Is there a bead product that will make duplicating the curved angle in the existing drywall easy when I tape and mud?
Old 04-22-2014, 08:49 AM   #4
Rob
Robpo's Avatar
Rewards Points: 826
Originally Posted by eddj View Post
Thanks for reply.
Questions
The blocks are studs or nailer to attach sheetrock to. I would do one side then the other to tape. Maybe cut something out of plastic like old bucket to finish it.
The Following User Says Thank You to Robpo For This Useful Post:
eddj (04-22-2014)
Old 04-22-2014, 08:53 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,524
Back of a big spoon will work also.
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
eddj (04-22-2014), Robpo (04-22-2014)
Old 04-22-2014, 01:39 PM   #6
I take it that the plastic or spoon is used to shape the mud into the desire shape to match the existing drywall?
Correct?
I would have thought there was a bead I could buy in this shape? No?
Thanks.
Old 04-22-2014, 02:04 PM   #7
Rob
Robpo's Avatar
Rewards Points: 826
Correct?
Thanks.
no just tape, bead is for outside corners
Old 04-22-2014, 09:09 PM   #8
Rewards Points: 376
Somewhere in the inter world there is a great video of a guy doing corner work on interior stucco with a tequila bottle! Find something that matches the curve and have at it! Ron
ront02769 is offline   Reply With Quote
Old 04-22-2014, 09:24 PM   #9
Don't listen to Ronto.....
I've tried it with a Teqilla bottle.... never even got to mixing the mud.
Old 04-23-2014, 04:18 PM   #10
Rewards Points: 5,974
Trim tex makes a 3/4" bull nose bead. Tried to do a link couldn't get it to work.
Old 04-25-2014, 03:05 PM   #11
Rewards Points: 454
Use straight flex tape you can get it in different widths it will make it a straight crisp corner.Then you can just use a straight tapping knife instead of a spoon,bottle, beer can that others are talking about, that's funny
scottktmrider is offline   Reply With Quote
Old 04-25-2014, 04:06 PM   #12
Forgot in my post the bull nose I was talking about is for inside corners. Scott they want a round corner.
Old 04-25-2014, 04:51 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,458
For the odd corners inside or outside...use something like this
ddawg16 is online now   Reply With Quote
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
eddj (04-25-2014), federer (05-20-2014)
Old 04-26-2014, 06:26 AM   #14
Dawg won't work for a round corner. Trim tex inside corner corner bead it's in their catalogue on line.
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 11:37 AM
Corner Post Leak seeker44 Roofing/Siding 4 03-01-2011 02:57 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 07:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 01:32 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
