Tips For Hanging Drywall Up Against Wavy Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-25-2013, 10:56 AM   #1
hboogz's Avatar
Rewards Points: 97
Tips for Hanging Drywall Up Against Wavy Ceiling
All -
I'm about to start some work and in the event I don't rip off the ceiling and start from scratch, what are some of your tips for hanging new drywall (on the wall) against an unlevel ceiling ?
I've read that I should measure 48" down from the ceiling at the opposite sides of the room where I plan on hanging, snap a line, and make sure the bottom (butted end) of the drywall sits at that line.
My question then becomes what happens to the gap between the wall and ceiling? Say I'm short maybe 1/4" or let's get crazy and say 1/2", how would I remedy that so that when I'm finished it looks like a nice straight line ?
Thanks,
Harry.
hboogz is offline   Reply With Quote
Old 11-25-2013, 11:42 AM   #2
Rewards Points: 5,974
Even if you get the walls straight the ceiling is still going to look wavy even after doing all this work and really take away from it. If you are going this far I would remove the ceiling, find out why it is wavy then fix, then do the walls. Also when you do your walls use a long level on the studs to make sure they are straight. It's very disappointing to do a big job like this then it not look right.
The Following User Says Thank You to ToolSeeker For This Useful Post:
kwikfishron (11-25-2013)
Old 11-25-2013, 11:46 AM   #3
hboogz's Avatar
Rewards Points: 97
I hear you, trust me. It's probably what I will end up doing but am really curious since I know a lot of folks on here are in the remodeling business so I'm sure there may be times that they have put up walls against a wavy ceiling.
Old 11-25-2013, 02:17 PM   #4
Rewards Points: 13,468
Can it be done yes, is it the right way no, and would look like poop.
Old 11-25-2013, 03:00 PM   #5
hboogz's Avatar
Rewards Points: 97
I hear you guys and am a proponent of putting the extra work in to make sure it's done right the first time. I was just curious if there was an industry tip that other folks have done in those events where time was prohibitive.
At any rate, let's talk how then you guys fix an unlevel ceiling ?
I've seen the contractortalk post about stacking 2x3 metal studs on top of the joints and running a string line ? If you do that, do you notch the metal studs and attach blocking between joists to accommodate recess lighting, etc ?
If you're using a laser level, are you attaching the level to the lowest joist, then sistering each joist and measuring the distance on each sister joist to the laser to confirm all the measurements are the same ?
Old 11-25-2013, 04:00 PM   #6
DIY staff
Rewards Points: 7,174
You lost me with the level line four feet from the ceiling---
If you are going to leave the ceiling for another time---just hang the sheet tight as can be to the ceiling.Taping that so it looks presentable will be hard--use straight flex tape in the ceiling/wall joint.
How you straighten out the ceiling depends a lot on the width of the room---narrow room? --Let us know what you have.
Old 11-25-2013, 04:22 PM   #7
We're not trying to beat you up here, we really want to help you that's why we're here. To level the wavy ceiling could entail anything from jacking up the joists and sistering another to it, one is cracked and needs replaced, to something as simple as some shims. Until we know why it's wavy we really can't tell you how to fix it.
Old 11-26-2013, 07:02 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
We did a huge addition back in 2004 and to save money for the project we left a large dining room ceiling up in the middle of our additions/add ons. after everything was moving along we found a huge dip in the middle of that ceiling near the chandelier. after much debating about what to do( remove ceiling etc...)we decided to work it out so I pulled mud from the dip and spread it way out 360 degrees effectively hiding the dip. this was a solution for one bad spot in the whole ceiling but a bad wavy ceiling throughout is something altogether different.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
oh'mike (11-26-2013)
Old 11-26-2013, 08:27 AM   #9
hboogz's Avatar
Rewards Points: 97
Mike, Thanks for the reply. I read that 48" remark from the following blog
http://ana-white.com/2013/05/momplex...-hanging-guide
It's certainly not scripture, but I found that technique curious and wondered if it was something that was adhered to by a lot of folks.
The room I'm working with is on the smaller side. It's about 10x12. There is a height mismatch, since some walls were removed - I plan on taking pics and posting them. The joists span the entire length of the house horizontally.
Having never leveled off a ceiling I've always been curious to hear what's been done out there, especially with using a laser.
No worries man, I totally hear you and appreciate all the feedback received. I plan on posting pics and like many, just really curious on getting things done really well.
The Following User Says Thank You to hboogz For This Useful Post:
ToolSeeker (11-26-2013)
Old 11-26-2013, 09:12 AM   #10
I read your link and I understand why he did it that way but I really don't agree with it. It would make the sheet level at the seam but really isn't that important. And doing it that way could leave some monster gaps on the ceiling. If you push the sheet tight against the ceiling that will let you adjust a little at the seam and a little at the floor where the baseboard will hide it.
drywall or sheetmetal ceiling drmax Building & Construction 12 09-21-2012 08:15 AM
Drywall doesn't line up on ceiling thebrandnewguy Building & Construction 6 09-14-2011 07:23 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 09:11 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
