Tips On Finishing Wall After Removed - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 10:59 PM   #1
Rewards Points: 85
Tips on finishing wall after removed
I am looking to remove the archway separating my kitchen from my breakfast nook. Once it is removed obviously I am going to have about a 6 inch strip that needs finished on two walls and the ceiling. How should I go about dry walling and finishing these strips? I am a novice to drywall so any help would be appreciated. I believe the walls are currently plaster. They also have an awful texture on them which I am going to skim coat to smooth. Thanks
Whyjune1st is offline   Reply With Quote
Old 03-18-2014, 02:11 PM   #2
Rewards Points: 454
You might be better off if you can afford it is to get a pro in there. That's not a good place in the house to practice tapping
scottktmrider is offline   Reply With Quote
Old 03-18-2014, 04:37 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
load bearing wall???
chrisn is online now   Reply With Quote
Old 03-18-2014, 05:43 PM   #4
Rewards Points: 85
What makes you think this wall is load bearing? I actually have another thread devoted to people's opinion on if it is load bearing or not. Remodeling Kitchen - Wall Must Go
Your input on that issue would be greatly appreciated.
Old 03-18-2014, 05:47 PM   #5
Rewards Points: 454
I wouldn't worry about it being load bearing its not long enough to be carrying that much weight plus the other walls are so close to it
Old 03-19-2014, 02:41 AM   #6
chrisn's Avatar
Rewards Points: 496
I don't know if it is or not, but I sure would want to make sure before you start tearing in out.
Old 03-19-2014, 06:55 AM   #7
Rewards Points: 5,978
Shouldn't matter either way the header should be above the arch if it's load bearing.
Old 03-19-2014, 11:42 AM   #8
Rewards Points: 512
with that window there it will shine directly on that wall and you will see any flaw in your work. if you do it yourself i'll cut it back to the closes studs beside the wall being removed so you dont have a 6" bump out where the wall use to be
princelake is offline   Reply With Quote
Finishing an exterior wall that extends beyond the wall above. RockingM82 Building & Construction 2 03-28-2012 04:49 PM
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 08:16 AM
preperation to paint after wall/ P removed deck hand Painting 4 12-06-2009 12:33 PM
Repair drywall behind mirrored wall that were removed Donna34655 Drywall & Plaster 2 05-10-2009 04:42 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
