Tiny Holes In The Wall : Using Joint Compound Appropriate?? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 06:51 AM   #1
tiny holes in the wall : using joint compound appropriate??
i am about to cover up the holes left behind from the screw( less than 1/2 a dime size) of toilet paper holder. I am not going to replace it back but cover the holes and paint. I only have the joint compound in the house about 4 years old. I typically use the crackle for small tiny nail holes or to level a small area. Their is liquid at the top of the container. I would mix it but I wonder if 1. it is any good anymore and too if it will do this job???
antoinette is offline   Reply With Quote
Old 04-02-2012, 08:14 AM   #2
Rewards Points: 13,468
Stur it up and see if there's mold in it. If it was unopened it should work.
Make sure to prime over it befor painting.
Old 04-06-2012, 12:57 PM   #3
Drywall contractor
Rewards Points: 1,070
If it's 4 years old and has separated, I wouldn't use it....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Primer and Joint Compound Issues RIVO Painting 15 07-19-2013 10:47 AM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
joint compound on concrete wall skuter1 Drywall & Plaster 2 05-25-2011 11:33 PM
spackle compound for filling wall holes amakarevic Drywall & Plaster 1 01-21-2011 07:21 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
