Tiny Holes In Compound - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 03:38 PM   #1
Rewards Points: 874
Tiny Holes in Compound
AL the work is done and looks good but I noticed in one or to areas there is a patch of tiny holes as you see in the pic. Why is that? Will the primer fill it? I really to put any compound on it for the fear of making it worse. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 04-07-2013, 03:54 PM   #2
Rewards Points: 258
I have never encountered holes like these. Exactly how big are they? What type of drywall compound did you use? I'm guessing there were air bubbles that burst but that is just a guess. Unless these holes are really tiny, ie. pinholes, you have to fill them with compound. Primer won't do the trick. Probably a pro will know what caused the holes. Did you by any chance stir premixed compound with a paddle attached to a drill after adding some water?
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
The Following User Says Thank You to retired guy 60 For This Useful Post:
Mstrlucky74 (04-10-2013)
Old 04-07-2013, 05:23 PM   #3
Trucon01's Avatar
Rewards Points: 510
Usually happens when you apply it too thick
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
The Following User Says Thank You to Trucon01 For This Useful Post:
Old 04-07-2013, 05:33 PM   #4
Rewards Points: 12
Put a thin coat of compound over it to fill the holes then sand it when it's dry.
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 04-07-2013, 05:42 PM   #5
Rewards Points: 13,274
Are you still trying to use Durabond to do this?
http://www.usg.com/sheetrock-lite-to...-compound.html
Old 04-07-2013, 06:56 PM   #6
Rewards Points: 512
are you doing drywall or making a cake?? looks like mud was slapped on then sanded. yup skim coat it, sand prime paint.
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 04-07-2013, 07:07 PM   #7
Rewards Points: 5,974
If you mix with a high speed drill it can also cause bubbles. Must be skimmed no way will primer fill those. And when you skim make your mud thin, not to be confused with runny.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 04-09-2013, 10:16 AM   #8
Rewards Points: 874
When you say thin, should I add some water to the compound? It is not much so I think I can do this myself. It is like two areas. Thanks.
Old 04-09-2013, 01:00 PM   #9
Rewards Points: 744
Yes, it should be about the consistency of sour cream, if not a little thicker.
Lay the mud on, then lightly scrape it off w/ your knife held at a 45 degree angle (of course, pull the blade across, rather than push it). If done right, this coat should only fill those hold, as opposed to adding more thickness.
Seattle2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Seattle2k For This Useful Post:
Mstrlucky74 (04-10-2013), ToolSeeker (04-09-2013)
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Corners are cracking as joint compound dries hoffmandirt Drywall & Plaster 6 04-24-2012 10:33 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
Interior: Preserving Installation Screw Holes During Skim coating? Lovegasoline Building & Construction 4 09-29-2009 04:03 PM
