-   -   Tiny Holes in Compound (http://www.diychatroom.com/f101/tiny-holes-compound-176498/)
Mstrlucky74 04-07-2013 02:38 PM
265 Attachment(s)
AL the work is done and looks good but I noticed in one or to areas there is a patch of tiny holes as you see in the pic. Why is that? Will the primer fill it? I really to put any compound on it for the fear of making it worse. Thanks
retired guy 60 04-07-2013 02:54 PM
I have never encountered holes like these. Exactly how big are they? What type of drywall compound did you use? I'm guessing there were air bubbles that burst but that is just a guess. Unless these holes are really tiny, ie. pinholes, you have to fill them with compound. Primer won't do the trick. Probably a pro will know what caused the holes. Did you by any chance stir premixed compound with a paddle attached to a drill after adding some water?
Trucon01 04-07-2013 04:23 PM
Usually happens when you apply it too thick
djlandkpl 04-07-2013 04:33 PM
Put a thin coat of compound over it to fill the holes then sand it when it's dry.
joecaption 04-07-2013 04:42 PM
Are you still trying to use Durabond to do this?
http://www.usg.com/sheetrock-lite-to...-compound.html
princelake 04-07-2013 05:56 PM
are you doing drywall or making a cake?? looks like mud was slapped on then sanded. yup skim coat it, sand prime paint.
ToolSeeker 04-07-2013 06:07 PM
If you mix with a high speed drill it can also cause bubbles. Must be skimmed no way will primer fill those. And when you skim make your mud thin, not to be confused with runny.
Mstrlucky74 04-09-2013 09:16 AM
265 Attachment(s)
When you say thin, should I add some water to the compound? It is not much so I think I can do this myself. It is like two areas. Thanks.
Seattle2k 04-09-2013 12:00 PM
Yes, it should be about the consistency of sour cream, if not a little thicker.
Lay the mud on, then lightly scrape it off w/ your knife held at a 45 degree angle (of course, pull the blade across, rather than push it). If done right, this coat should only fill those hold, as opposed to adding more thickness.
