Tin Behind A Stud? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-20-2012, 10:14 AM   #1
Tin Behind a Stud?
I drilled through a stud and rand into a piece of tin. Through a bit more inspection, it might be some sort of box. The only thing I can come up with is an old knob and tube box, but that's all I got. It appears to be double walled, and is not part of any laundry chute. Could anyone with experience with old plaster/lath (house circa 1930s) walls shed some light? Much thanks in advance.
Here's a shot of the drilled hole with the tin behind it:
http://imgur.com/ZlGpT
WeirdFlatMinor is offline   Reply With Quote
Old 07-20-2012, 12:33 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Could be an air duct.
Old 07-21-2012, 01:30 PM   #3
Is that an interior wall or an exterior wall?
bhry is offline   Reply With Quote
Old 07-21-2012, 10:50 PM   #4
Interior. Not an air duct as the whole house is radiator heat.
Old 07-21-2012, 10:53 PM   #5
bbo
dimensions of box? dumbwaiter channel?
bbo is offline   Reply With Quote
Old 07-26-2012, 11:22 AM   #6
Drywall contractor
Rewards Points: 1,070
If it's double wall, it seems like it would be some sort of exhaust for a furnace, water heater, etc. that may have been removed at some point, but the pipe was left???
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-26-2012, 12:11 PM   #7
retired union carpenter
Send a message via Yahoo to coupe
looks like an air duct or return to me
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 07-26-2012, 01:39 PM   #8
Bill Kearney
Rewards Points: 1,174
It's likely an electrical box or someone nailed a strip of metal up because there's something else behind it. See anything through that hole?
wkearney99 is offline   Reply With Quote
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 07:48 AM
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 01:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
Is it safe to remove this stud? lofar Remodeling 4 06-17-2009 12:22 AM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 09:24 PM
