Tile Trim...leave Room For Grout? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 10:03 AM   #1
Tile trim...leave room for grout?
I will be using a bull nose tile trim on some mosaic tiles to frame the shower surround. This way I'll avoid having to try to make a clean grout line between the tiles and the wall.
But, seeing instructional videos that don't jive with some instructions. The instructions said to leave a bit of space between the tile and the trim. This way you can get grout in there. So looking at finished product it would be....Wall, Trim edge, Grout, Tile strips, Grout, shower surround.
The videos I am seeing appear to be sliding the tile flush and tight to the trim. No room left to get grout in there.
sablesurfer is offline   Reply With Quote
Old 06-11-2013, 12:58 PM   #2
I think I have figured out the issue. Some of the tile trim out there has the tile right up against the edge. But others actually have a secondary border that bumps out a bit more than the actual outside edge. I am assuming that I run the tiles up to that ridge, then grout into the tiny space left?
Old 06-11-2013, 09:44 PM   #3
Rewards Points: 952
You second post is correct. And you don't grout in this application, you caulk.
cleveman is online now   Reply With Quote
Old 06-12-2013, 08:11 AM   #4
Thank you.
Speaking of caulking, it appears I use both grout and caulk on these mosaic tiles. I will grout inbetween the tiles and caulk the edges along the shower surround and the edge at the tile trim?
Trim around window that has tile installed halfway up recess? dleopold623 Windows and Doors 2 03-27-2013 06:58 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Trim for a sunken living room JBravo Flooring 1 07-15-2009 07:59 PM
bath room tiling question, laying tile around a curve everyman Kitchen & Bath Remodeling 2 02-14-2009 01:21 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
