Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-18-2011, 08:39 PM   #1
tile over old drywall that has peeling paper
I removed the tiles from my bathroom shower. The drywall is intact, but the paper is peeling from the adhesive that was attached to the tile. Can I tile over this drywall, or do I need to replace it? Is there any type of product that I might be able to use to put over the peeling paper without having to take out the drywall?
Hely is offline   Reply With Quote
Old 07-18-2011, 08:46 PM   #2
You should remove all your old drywall and install durock.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Hely (07-18-2011)
Old 07-18-2011, 10:30 PM   #3
Tileguy
Bud Cline's Avatar
Drywall doesn't belong in a shower.
How do you intersect drywall (or in my case plaster) into tile on the same plane? Proby Kitchen & Bath Remodeling 5 08-02-2010 06:51 PM
Plaster guard surface flush with finished wall? Drywall or with tile? Stephen S. Plumbing 1 06-21-2010 07:49 PM
Improving a bad tile to drywall transition navi_jen Drywall & Plaster 5 10-12-2009 09:32 AM
mixing tile and drywall rocketdoctor Drywall & Plaster 1 10-09-2009 01:17 PM
Bathroom ceiling primer and the paper peeling off beedee Painting 10 09-05-2009 01:35 PM
