Thinning Mud For Texturing - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 02:21 PM   #1
Thinning mud for texturing
I have a 2 part question:
1. How much water do I add to the mud, or what is the correct consistancy of the mud for texturing?
2. I plan to do a knockdown pattern, how long should I let the mud dry after I textured it to knock the points off?
Smoke is offline   Reply With Quote
Old 04-14-2012, 09:44 PM   #2
Rewards Points: 12,804
http://search.yahoo.com/search?ei=ut...9,18370,0,18,0
Old 04-14-2012, 09:52 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Knockdown is applied with a dedicated texture-spray-gun, at a specific nozzle setting.
Be forewarned; propper texture application is not something accomplished easily by amatures (sp), or novices.
Excellent site: http://www.drywallschool.com/textures.htm
ALWAYS: "Test" (apply,and do your initial texture pattern) on a scrap piece of material before you apply on the actual surface.
- Build Well -
Old 04-14-2012, 10:57 PM   #4
Thanks for the links!!! Very Helpful!!!!
thinning solid stain patandsusan Painting 2 04-08-2012 12:32 PM
thinning an exterior oil based primer knorseman Painting 1 07-21-2011 06:05 PM
Thinning Paint Bob Guercio Painting 12 04-12-2011 07:46 PM
Thinning Joint Compund mopowers Building & Construction 1 08-25-2009 04:06 PM
thinning out thick paint/drips before new paint bonanz Painting 3 09-24-2007 01:31 AM
