Texture Wall Or Ceiling First? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 09:39 PM   #1
Texture wall or ceiling first?
I've got about a 2'x5' area on the ceiling that I've got to match a crowsfoot texture and about the same area on the wall that has orange peel that I've got to match and blend. Which area do I do first so I dont mess up the other?
Pierson Paint is offline   Reply With Quote
Old 11-30-2011, 10:23 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would stomp the ceiling first and let it dry completely then shield the wall when I did it. If anything gets past the shield it can be (lightly) wiped from the ceiling with a sponge.
The Following User Says Thank You to Bud Cline For This Useful Post:
Pierson Paint (12-01-2011)
Old 12-01-2011, 07:15 AM   #3
A Little Of Everything
Rewards Points: 1,364
What Bud said.
Stuff falls down. If bits & pieces fall off your wall (which they will) they won't fall on the finished ceiling.
DrHicks is offline   Reply With Quote
Old 12-01-2011, 07:53 AM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Ceiling first as already mentioned you don't want ceiling mud falling back onto your finished walls. Other than that it does'nt matter.
titanoman is offline   Reply With Quote
New walls, old ceiling with texture... do I tape? rodney23 Drywall & Plaster 12 02-15-2011 10:38 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
partition wall parallel to ceiling joist RedBear Building & Construction 10 03-05-2010 11:37 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
