Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-11-2010, 11:02 AM   #1
Mod
kwikfishron's Avatar
Texture over Texture
I’m currently repairing a water damaged ceiling that will require couple of patches and in other areas just peeling paint. Since overall about 1/3 of the area will be affected I can see trying to match the lightly brushed textured look would be a nightmare, so I want to re-texture the whole ceiling.
1) Is there a problem applying new texture over old painted texture after peeling the water damaged paint back as far as I can?
2) Since the original is a very lightly brushed texture that flows from this room into another (that I’m trying to match) can I thin down the compound to the point were I can roll it on and then try to achieve the brushed look?
Any help would be appreciated,
Thanks.
kwikfishron is online now   Reply With Quote
Old 03-11-2010, 09:54 PM   #2
Pictures would be very helpful.
some textures can be very difficult to get close.
Big Bob is offline   Reply With Quote
Old 03-12-2010, 05:52 AM   #3
sdsester's Avatar
Make sure to prime before you do anything else so the new texture has something to stick to. You might try the texturing technique out on some drywall scraps before taking on the ceiling to see what tools you are really going to need?
sdsester is offline   Reply With Quote
Old 03-12-2010, 02:01 PM   #4
Drywall contractor
You'll probably need to scrape/sand the texture as best you can then skim coat to get the surface "reasonably" smooth. Then re-texture. Just going over what's there won't do well. The old pattern will "telegraph" through unless you make the new texture MUCH heavier. As Bob said, a picture would help....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
primer not adhering to drywall texture? eli_carson Drywall & Plaster 10 08-18-2009 02:46 PM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 07:24 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
