Texture In New Kitchen? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 08:31 AM   #1
texture in new kitchen?
Hi All,
I am in the middle of remodeling my kitchen and have reached the point where I am almost ready to apply texture to the ceiling and walls. The texture will be a light orange peel. Most of the walls will be covered by the cabinets and tile but there are still many areas I would like to texture. Is texture a problem under tile? Should I mask off those areas?
Thanks in advance...
Dave
tgidave is offline   Reply With Quote
Old 08-28-2012, 08:40 AM   #2
Rewards Points: 13,732
You do know texture in a kitchen or bathroom is near impossible to clean and degrease, and a lot harder to make repairs to.
I would install the tile first, then texture.
If you mess up in your masking off you would be stuck trying to fill in areas or sand it off.
Just use some 2" wide blue tape to mask over the edges of the tile when texturing and painting.
Old 08-28-2012, 10:32 AM   #3
So, other than texture, what is the recommended wall and ceiling treatment for kitchens? The dry wall is up and I am working on finishing off the taping.
Dave
Old 08-28-2012, 10:39 AM   #4
Newbie Bill
Rewards Points: 522
Around here you only see textured walls in 1970's basements. The norm is do prep and paint the drywall.
Around here textured ceilings are still the most common ceiling finish but when we redid our kitchen, we had the texture removed and went with a smooth ceiling.
It all comes down to personal preference.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 08-28-2012, 10:40 AM   #5
Just prime and paint them.
You could add an accent color on a wall,
Add a simple chair rail.
Wainscot with a chair rail.
Crown moulding.
Old 08-28-2012, 04:52 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
Dave
Ahhh, paint?
Old 08-29-2012, 01:36 PM   #7
Drywall contractor
Rewards Points: 1,070
Smooth walls and ceilings.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Kitchen backsplash over knockdown texture? Ponderous Remodeling 2 01-17-2010 04:14 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
