Texture? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-27-2009, 10:42 AM   #1
texture?
can i use the joint compound and do a final skim coat over the newly taped drywall to get it nice and even??
thanks for any advice,
jim
fishtale is offline   Reply With Quote
Old 12-27-2009, 12:00 PM   #2
Remodeling Contractor
yes. A level 5 finish is when you use the compound for a final skim coat to float out an even smooth wall.
Old 12-28-2009, 04:29 PM   #3
Drywall contractor
Rewards Points: 1,070
If you have a large area to do, thin the mud in a 5 gal. bucket, have one person roll it on and another wipe it back off with a broad knife. Lightly sand the entire surface, prime and paint....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 06:24 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 04:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
Repairing dry wall and matching texture? Doug Crf Building & Construction 1 08-17-2006 03:50 PM
