Tell Me About Stippled Ceilings - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-06-2014, 01:02 PM   #1
Rewards Points: 121
Tell me about stippled ceilings
I am in Canada and our house is 39 yrs old.Our living room has a stippled ceiling as does one bedroom . The bedroom we are re-doing with new paint and flooring.
i was reading about stipple ceiling possibly having asbestos, now we have been here over 25 yrs and never knew that..
I know the right thing to do is take a sample and send it away to test.. But as long as this ceiling is left alone should it not be ok.
my plan was to spray the ceiling.. I really dont want to replace it, but for interest sake, if you put drywall over top of stipple does that eliminate the threat, just seeking out options..
rick31797 is offline   Reply With Quote
Old 07-06-2014, 01:40 PM   #2
Rewards Points: 5,988
Asbestos is only a threat when it is disturbed as in sanding as that puts the fibers in the air.
ToolSeeker is online now   Reply With Quote
Old 07-11-2014, 11:23 AM   #3
Drywall contractor
Rewards Points: 1,070
Asbestos has not been used in drywall products since 1975. Even if you put another layer over the existing ceiling, you would need to scrape down the texture and get it reasonably flat so your nails or screws will pull up properly.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-11-2014, 07:14 PM   #4
Rewards Points: 14,014
Just painting over it would be a whole lot easier then going over it with new drywall.
Unless you want a flat ceiling.
Old 07-12-2014, 10:03 AM   #5
Please post a pic of what you are calling stipple. Different areas call different textures by different names, therefore the means to deal with it will depend on what it is.
Old 07-12-2014, 12:35 PM   #6
Rewards Points: 402
We had the stomp ceilings in our kitchen, and I scraped all the little points down, and called a drywall contractor. It was about 500sq' so it was a decent amount. He put 3 coats of drywall compound over it all, smoothed it out, sanded it, and it's perfect now. It only cost me about $550, and it was the best money ever spent!
taylorjm is offline   Reply With Quote
Re: Unvented cathedral ceilings redpine17 Insulation 7 08-05-2013 11:50 AM
Replacing tape joint on stippled ceiling Rusty Skillz Drywall & Plaster 4 11-01-2012 08:41 PM
insulation in slanted ceilings dhonn Insulation 10 05-05-2011 12:38 AM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
hate the stippled ceilings Litamd Painting 7 01-01-2007 08:42 PM
