Taping A Very Tight Inside Corner? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 08:38 AM   #1
Taping a very tight inside corner?
Above a shower stall there is only about 3/4 of an inch of clearance on the wall above the tile and below the ceiling. Not enough for a full/proper tape job in this tight corner.
Should I cut down the tape to fit here? If so, does the tape need to have some clearance from the tile, or can I run it almost to the tile.
I'd rather not remove/reset the tile for obvious reasons.
echase is offline   Reply With Quote
Old 03-10-2010, 07:37 PM   #2
Remodeling Contractor
just trim the edge against the tile with a sharp razor knife. Compound as usual. Caulk along the edge of the tile
Old 03-10-2010, 08:34 PM   #3
Thank you Bob!
Left or right hand crown inside corner? Klawman Carpentry 9 01-08-2010 03:19 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
one corner of secornd floor room is low 99th_Flyby General DIY Discussions 9 01-12-2009 08:25 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
