-   -   Taping a very tight inside corner? (http://www.diychatroom.com/f101/taping-very-tight-inside-corner-66454/)
echase 03-10-2010 09:38 AM
Above a shower stall there is only about 3/4 of an inch of clearance on the wall above the tile and below the ceiling. Not enough for a full/proper tape job in this tight corner.
Should I cut down the tape to fit here? If so, does the tape need to have some clearance from the tile, or can I run it almost to the tile.
I'd rather not remove/reset the tile for obvious reasons.
Bob Mariani 03-10-2010 08:37 PM
just trim the edge against the tile with a sharp razor knife. Compound as usual. Caulk along the edge of the tile
echase 03-10-2010 09:34 PM
Thank you Bob!
