Taping Questions - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 10:11 AM   #1
taping questions
So i was just told that I should not have used fiberglass tape for my corners. I am wondering would it be ok to sand down to the tape and apply paper tape? or what should i do? most of the time i get the fuberglass texture through the mud.
What are my options? WHat should I do? What supplies do I need?
baum is offline   Reply With Quote
Old 01-23-2010, 08:26 PM   #2
firehawkmph's Avatar
Rewards Points: 1,920
Baum,
I'm assuming you are talking about inside corners. If that's the case, there's nothing wrong with using fiberglass tape, I do it all the time and prefer it on small jobs. Outside corners should use corner bead.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-24-2010, 02:48 AM   #3
Too Short? Cut it Again!
I don't like using mesh but since you have there is not reason to redo it so long as it is not buckled or anything. And as mentioned, I assume you talking your inside corners.
You just need to build up and skim out more mud until the mesh does not show.
You may find an inside corner finishing tool handy.
Old 01-24-2010, 08:28 AM   #4
Thanks for the advice guys. Yes its the inside corners. I used the corner bead for the outside. I dont know if you would call this a small job. its a 650sf basement finish. With a couple soffits.
Old 01-24-2010, 10:13 AM   #5
Just saw the small corner finishing tools on sale in the Sunday paper at a box store for $6 each or something. Mine are larger and nice and flexible and I think I paid $10 which would make them $15 or so retail?
Nothing beats a nice long drywal knife either. Pay for a good one that fits a drywall pan and take care of it? You will have it for a lifetime.
Old 01-24-2010, 07:16 PM   #6
Sd,
I still have my ss mud pan I bought when I was about 17. It has fully welded corners instead of the folded over flaps. Makes it easier to clean and it just looks nicer. So that makes is about 35 years old. I had one homeowner use it once for wetting her wallpaper borders. She wanted to keep it after that. I told her no way sister, there's a lot of history in that pan, and a lot of good years left.
Mike Hawkins
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 12:36 PM
When to sand and other questions... PaintedSurface Painting 4 03-27-2009 09:13 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
