Taping And Mudding Behind Shower Stall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 08:55 AM   #1
taping and mudding behind shower stall
I just bought a new Maax shower stall and I still need to put up greenboard behind the stall but I'm wondering if I need to tape and mud any joints. The only joint I will have is in the corner, which still needs to be framed out. Any help would be great!!
BobLoblaw is offline   Reply With Quote
Old 04-07-2012, 11:43 AM   #2
Rewards Points: 14,312
Any stall I've seen gets attached directly to the studs with no drywall behind it.
If you do it your way there no way to cover over the nailing flanges without adding another layer of drywall over the one you put up.
BobLoblaw (04-09-2012)
Old 04-07-2012, 11:56 AM   #3
This type of stall came with a base, two wall panels and a corner caddy. In the installation instructions it says to apply adhesive to the back of the wall panels and position the panel on the back wall.
Old 04-07-2012, 12:13 PM   #4
just tape what is visible above the shower stall
The Following User Says Thank You to DannyT For This Useful Post:
Old 04-07-2012, 01:14 PM   #5
Rewards Points: 512
i gotta say i love your name on here! arrested development is amazing show!
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 04-07-2012, 03:41 PM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You do not need to tape or coat seams behind the shower panel system.
Regarding what should go behind the shower panel system:
Some shower panels systems do require a backer, behind the unit, to strengthen the panels (the panels are thinner and require additional rigidity).
Some (most system) don't and are designed (with thicker panels & materials) so as to be attached directly to wall framing studs.
If the manufacturer stipulates a backer, or surface behind the unit's panels, you should use cement board, not MR board. It will be stronger and will also not deteriorate, or soften, if you have any water leakage in the near or distant future.
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Shower stall paint job gone horribly wrong! MOsteve Painting 11 11-27-2011 11:37 AM
taping and mudding backerboard in a shower kathyll Building & Construction 3 07-09-2011 05:53 PM
Dry Wall mudding mmohanna Building & Construction 3 11-21-2009 07:34 PM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 02:23 PM
