01-19-2011, 12:24 PM
#1
taping and finishing inside corners
my wrist has been hurting lately from using knives and pan. is there a way to tape and or finish inside corners using the hawk and trowel? it always comes out too sloppy.
01-19-2011, 12:36 PM
#2
Stay-at-home GC
Practice
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-19-2011, 04:21 PM
#3
Are you using a 4 inch knife? Takes less mud than a 6".
01-19-2011, 05:10 PM
#4
6" knife works good for corners without being overly big. I always switch hands every so often. If the corners are coming out sloppy, it won't be any different with a hawk and trowel, probably worse. Don't load your knife up too much and take your time.
Mike Hawkins
01-20-2011, 12:53 AM
#5
Moderator
This guy is good; if this one is not the inside corners, he has many more others nearby; http://www.youtube.com/watch?v=21GBDgkL3WE&NR=1
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
01-21-2011, 12:05 PM
#6
i tape with the 4" and finish with the 6" for finish ill do one side of the corner with the 6" then the next day do the other side. i just wondered if anyone ever used the trowel for corners.
01-21-2011, 12:50 PM
#7
They do make a corner trowel, that you can finish both sides at the same time. I found that they are usually more rounded than square when you get done. Thus causing trouble with areas like baseboard trim.
01-22-2011, 01:13 PM
#8
Drywall contractor
I wouldn't recommend a corner trowel. Drewhart's advice is sound. Personally, I use a 5" knife for taping and bed coat on angles...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
01-22-2011, 02:30 PM
#9
Just use caulking......if you have wallboard that's nice and tight at the inside corners, caulking saves you so much work. I know many will criticize me for saying so, but I've done it for years with no callbacks.
01-22-2011, 03:14 PM
#10
Drywall contractor
I wouldn't recommend that either....
01-23-2011, 02:47 PM
#11
People like you keep me very busy. I just started tearing out a 'finished basement' in a million dollar home friday do to shoddy work. Thanks,
Mike Hawkins
01-23-2011, 02:57 PM
#12
old guy contractor
Originally Posted by GBR in WA
Frenchmen have ALWAYS been the best tapers.
With a name like Laurier Desormeaux you know he's gonna be good!!!
Good video der!!!
01-23-2011, 06:08 PM
#13
for a diyer i wouldnt advise a corner trowel , they take time to get used to and are more for the professional ... plus id advise using a banjo for taping at minumin.. taping like that is to slow bedding with a knife ..use a banjo ...
01-23-2011, 11:26 PM
#14
Mike Hawkins
Mike, it wasn't a truly serious suggestion, but, since the poor guy was saying how sloppy his inside corners were, I provided a solution, maybe not entirely a professional solution......however, I've done it in a pinch, returned to the job even years later and the corners are just as tight as any finished drywall corner. It's an option......
01-24-2011, 08:05 AM
#15
i use 20 min mud for corners especially.
I do the one side of all corners and by the time I do the last corner the first one is ready for the second side.
When it comes to finish coat, one side per day.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
